Leading AI Architecture Design Tool with Real-Time Rendering Integration
ホーム
ブログ
Architects are known for their innovative ideas when designing buildings and spaces. However, the process of turning concepts into visuals can be time-consuming and mentally exhausting, and it's common for designers to experience creative blocks or even lose their initial ideas during the process.
That's why D5 Hi, an AI conceptual design tool, was born: to help architects capture their concepts in a quick yet creative way, making design easier than starting from scratch yourself.
Despite being the most popular AI image tools currently available, stable diffusion and mid journey have steep learning curves when it comes to practical application in architecture. D5 Hi, however, is specifically designed and trained for spatial design, and is also integrated with real-time rendering software D5 Render, ensuring that architects can quickly and easily bring AI-generated spatial concepts to life.
How D5 Hi is integrated into architectural design
Imagine having D5 Hi that seamlessly integrates into your architecture design workflow, allowing you to simply input basic sketches or even describe your ideas with words, and watch as D5 Hi generates 2D visuals with accuracy and impressive creativity.
Designers can convert these visualizations into stunning 3D walkthroughs/animations using D5 Render, significantly boosting work efficiency.
Put simply, the AI-powered architecture design workflow is:
D5 Hi for Rendering Refinements
"I uploaded a render I did on D5 (the left image) and then just prompted 'house, twilight' in D5 Hi with the Accurate mode (the right image). I find it VERY useful to check how the lighting should look and the overall ambiance of the scene. Then I can adjust my render for something similar(the third image)," said Xavier Alonso Mayorgarodz.
Image Credit: Xavier Alonso Mayorgarodz
D5 Hi for Rendering Atmosphere Previews
Jamstech Studios uploaded their own SketchUp model onto D5 Hi and generated stunning conceptual images, providing clear direction for the atmosphere.
These conceptual images also provide clients with a quick preview, allowing them to choose their preferred atmosphere, thus avoiding the need for repetitive modifications during the later stages of the visualization process.
The Original Model
D5 Hi Visuals
Image Credit: Jamstech Studios
Quoc Phan, a professional interior designer, also tested the AI-powered concept-rendering workflow. He can "rely on the D5 Hi generated images as the basis of my complete project using D5 Render."
The Original Model
D5 Hi Visuals
A Basic Render in D5
Image Credit: Quoc Phan
D5 Render Free Download
How to Use D5 Hi
  1. After entering the D5 Hi page, please apply to join the waitlist and you will receive a confirmation email with details.
  2. Once your application is approved, you will receive an email notification, and then you can start experiencing D5 Hi.
*It is recommended to use an existing D5 email account to apply for membership.
Detailed Guide:
Say goodbye to Stable Diffusion and hello to a new era of intuitive design workflow integrated with D5 Hi & D5 Render!
Try D5 Hi
こちらもお気に召すかもしれません
KPF の D5 レンダリングによる革新的な飛躍
