How to turn 3d architecture models to drawings in seconds
Home
Blog
What It Does
After designers build their models and connect them to D5 Render, they can add supplementary elements like plants or vehicles—or simply render the scene as-is. Once AI Style Transfer is activated, D5 Render automatically transforms the rendered image into a hand-drawn style.
This feature is particularly useful when architecture drawings are required. Instead of manually sketching architectural concepts each time a modification is made, designers can rely on AI to generate stylized visuals instantly.
You can choose to fine-tune your models and renders to an ideal condition before converting them into drawings. Alternatively, you can edit your models first and generate rough hand-drawn-style renderings at each stage, then create polished 3D visualizations once the model is finalized.
In short, it streamlines the workflow:
Basic model → Architecture drawing → Refined model → Realistic render
How to Use It
Sync your model (from Rhino, Revit, SketchUp, Archicad, Vectorworks, Cinema 4D, or 3ds Max) to D5 Render using D5 Sync.
Add decorative models (e.g., plants, vehicles, furniture) if needed—or skip this step.
Render images from your desired perspectives.
Apply AI Style Transfer, select a preferred style (pen sketch, pencil sketch, watercolor, etc.), and generate the stylized image.
Necessary Preparation: D5 Sync & D5 Render
D5 Sync is a livesync plugin for major modeling software such as Revit, SketchUp, and Rhino. With livesync on, you can modify your models and observe their changes in D5 Render in real time.
Download D5 Render and D5 Sync from D5 official website.
Install D5 Sync and it will appear in the toolbar of modeling software.
Start livesync and add decorative elements like plants, materials, and vehicles in D5.
With this feature, you can effortlessly handle tasks whether in actual design projects or competitions. D5 Render also provides other handy tools for designers, like one-click outline mode for floor plans. Best of all, D5 Render is free to download and use—make sure to give it a try!
Download D5 Render
Contact Us
You might also like
The first 3d visualization collaboration platform
KPF's innovative leap with D5 Render
